Are there any differences in upper rear control arms between B4 Sedan and S2/RS2 Avant?
I currently have a 1993 B4 90 Quattro sedan. I have swapped the rear suspension to S2 Avant bearing carriers, hubs, axles etc. However, I still have my factory USA spec upper and lower control arms. From everything I can gather, the lower rear control arm is the same compared with the S2 ABY Avant & RS2 but I’m unsure about the upper control arms. Mine are the stamped steel versions. Asking here to confirm as I would rather not have any surprises with alignment when I get back to finish up at my friend’s shop.
I see these part numbers which are most likely the cast (A?) and the stamp steel (B?) versions.
8A0 505 323 A or B
8A0 505 324 A or B
It also lists these which are stamp steel too I believe but not sure the other differences.
8D0 505 323 B
8D0 505 324 B
I previously had been using B5 hubs in rear.
Any help is greatly appreciated.
8A0 505 323 A or B
8A0 505 324 A or B
8D0 505 323 B
8D0 505 324 B
