Having fitted PowerFlex front bushes (Audi rear upper control arm bushes), H&R springs and red Koni dampers to my RS2 I can confirm the car is transformed - though with 88,000 on the clock and assuming original parts this is to be expected
The recommended front Koni is fixed rate and the rear was set to a medium setting (those of you experiencing a loose rear with this may have the back set too hard so it skips, just a thought).
1) Less rear squat and rising bonnet under acceleration - strangely this makes the car feel quicker!
2) It also eliminated some of the driveline shunt I discussed elsewhere so it seems this was due to front/rear weight transfer during gear changes rather than duff engine/gearbox/diff mounts.
3) Vastly improved lateral stability under braking and reduced nose dive.
4) Elimination of a steering dead spot around the dead ahead position.
5) Improved turn-in reduced body roll and more faithful line in the bend.
6) The ability to gently dab the brakes mid bend if you misjudge entry speed or tightening apex without unduly disturbing the car - just gentle tuck in.
And I haven't even replaced the crappy Uniroyal tyres with Michelin Pilot Sport 2's yet... booked in to Micheldever for Friday, watch this space...
The recommended front Koni is fixed rate and the rear was set to a medium setting (those of you experiencing a loose rear with this may have the back set too hard so it skips, just a thought).1) Less rear squat and rising bonnet under acceleration - strangely this makes the car feel quicker!
) so with the ARBs it should be great.
Right now mine strikes a nice balance between scaring me shitless, making me seasick and tipping over on corners with the stock (rusty bedspring style) set up, especially with the 'teflon' grip leather seats.
