Replacement bolts
  • Mark Halligan
    • 2001
    Replacement bolts
    Hi
    does anyone know if replacement 'captive' bolts fitted to the forged wishbones are available anywhere?
    I have had to press mine out due to excessive corrosion any help would be much appreciated.
    Mark - Modded
  • s2driveruk
    • 12696
    wonder if a nut & bolt specialst would be able to source something? Could always try these guys, usually really helpful
    A.H.C (CAMBERLEY)
    415-417, London Rd, Camberley, Surrey GU15 3HZ
    Tel: 01276 709069
    Quick question, do they point down towards the road those bolts, pretty sure they do but need to confirm as i have a new pair to replace my pressed steel versions.
    1992 3b S2 Coupe
    • LHD_Kid
      • May 2006
      • 3695
      Easiest thing to get the correct thing would be to buy 3 rear locking plates and press the bolts out of them... would be identical, but cost about 6 quid for each plate....
      HTH
      Chris
      • Corey
        Banned
        • Sep 2003
        • 2793
        if you don't find out Mark I'll look tomorrow
        Corey
        01636 822288
        • Mark Halligan
          • 2001
          Thanks for answers
          HTH
          Chris
          Blimey good idea, I'm embarassed I never thought of that LOL
          David, yes they point down at the ground.
          Corey if you do find out anything that'd be handy , I won't be replacing them for a week or so, until they get back from being powder coated.
          Mark - Modded
          • NoNonsense
            Forum Sponsor
            • Apr 2004
            • 673
            i've ordered my replacement studs from the dealer and pressed them in myself. they were pretty inexpensive if I recall correctly.
            I'm sure Corey or VAGparts could get them for you.
            Joe "NoNonsense"
            axis motorsport
            joe@axismotorsport.com
            • Jas11n
              • 5067
              Never realised those were just pressed in
              I was going to offer to stud weld some more on for you at work Mark but obviously not the way they are done.
              Jas..
              2001 Avus Silver B5 RS4.
              1995 S2 Coupe - sold (sniff)
              • waad_uk
                • Jul 2006
                • 411
                Yeah I just welded 3 bolts in when mine went last month. Ground the heads down to a cone shape to allow a nice fillet to form - Job done. Audi said they could not get hold of anymore?!?
                If you do go down the welding route make sure you use high tensile bolts, and there is fair load on the threads when they are tightened up.
                '93 S2 Coupe
                • Mark Halligan
                  • 2001
                  Yep just did that, I had them blasted clean today and welded some 12.9 tensile bolts onto them. Off to the powder coater tomorrow now.
                  Mark - Modded
                  • s2avant
                    • 2426
                    For reference the press fit bolts are 893407745A. They retail at £1.30 + VAT each.
                    Ben
