Here's my situation:
I've got the entire rear suspension from a 90q20v sedan on the rear of my 4kq (B2 90q). This includes the two piece struts, factory sway bar set-up(actually running the 22mm FWD 4K bar now), and subframe. I've got a rear tie rod that has seized to the point where I can't get the car aligned correctly.
So, my problem is I do not know the VIN of the 90q20v of which I removed the suspension. There are two choices for tie rods 893 509 411 A and 893 509 411 B. Are the interchangeable? What is the difference between the two?
BTW, I've already looked, to no avail, on the existing tie rods for a part number.
Tom
Tom
