Bible bashers please
  • Azman
    • 3205
    Hi guys,
    Can some on with the good book please consult it as to wether the front legs (that the damper goes into and the wheel bearing housing bolts too) of a Coupe E have the same part number as those of a CQ20 please, please, please.
    Thanks.........
    I have a few thougths brewing you see, all will be revealed.
    Cheers in anticipation
    Az
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • s2dude
    • Nov 2005
    • 1631
    Well, im not exactly sure which car codes these come under in the bible but I can tell you that the Audi Coupe
    and Audi Coupe Quattro
    ACO and ACOQ share the same suspension strut
    893 412 033 E - left suspenion strut
    893 412 034 E - Right suspension strut
    Not sure if this helps you but its all I could find!
    • Skull
      • 3506
      • Country: Slovenia
      ehh... by the title i thought you were a deicide fan...
      Audi Quattro WR
      • Azman
        • 3205
        @ Skull - Eh?
        Dark Grey Avant
        RS2 FARB
        • Azman
          • 3205
          @ S2 dude, jsut to clarify, the CQ20 is 1990 car and the Coupe E is a Kreg just in case they changed anything, but other than that the assemblies should be the same?
          Az
          Dark Grey Avant
          RS2 FARB
          • mcandmar
            • Apr 2004
            • 5118
            deicide = death metal band ;-)
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • Skull
              • 3506
              • Country: Slovenia
              Originally posted by Azman
              @ Skull - Eh?
              Audi Quattro WR
              • CHEN
                • 329
                The 'K' reg coupe upper strut will have holes for 21mm headed hub housing bolts, your 20vCQ should only have 19mm headed hub holes. This would make them a loose fit on your 20vCQ
                • Flat on my back
                  • Jan 2007
                  • 2449
                  Meads of Asphodel myself, this needs a new thread.
                  Carlos.
                  • Azman
                    • 3205
                    @Chen- Eh? which bolts?
                    Do you mean the ones that bolt the hub to the leg?
                    Dark Grey Avant
                    RS2 FARB
                    • Azman
                      • 3205
                      Got you Chen That is no probs as I am using S2 hub carriers!!!!!!
                      Az
                      Dark Grey Avant
                      RS2 FARB
