S2 Avant rear track rod arms - Suppliers?
  • 951rpm
    • May 2007
    • 17
    Guys
    I need to source both rear track rod arms (Audi part no. 8A0501530C). It is a back order part through Audi, are there any other suppliers that are likely to stock these parts with immediate availability?
    Darren
    Eurocarparts and GSF will have none OEM versions.
    • 951rpm
      • May 2007
      • 17
      My man at Euro's reckoned they didn't stock S2 track rod arms, however I suppose it his not his marque so will go back to them and try again.
      Thanks
      Darren
        Could be the case as the Avant & Coupe bit are different IIRC
        Contact GSF and quote the Audi part number and see if they have an alternative.
        • Pete Reeve
          • May 2007
          • 584
          Quattro corner should be able to help if you have no luck
          One of the UK's leading suppliers of OEM Audi UR Quattro parts by mail order. Virtually any part available on request.
          Quattro Corner Audi OEM Parts
          • s2driveruk
            • 12696
            GSF don't stock though they can special order, were about £70+vat direct from the oem supplier.
            If you work hard enough u can free up - i did mine recently.....
            1992 3b S2 Coupe
            • 951rpm
              • May 2007
              • 17
              Thanks S2 Driver.
              I have lined up a few jobs to do now. The Caliper and disc upgrade is going to have to wait for a bit now!
              Darren
