pinging springs- help!
  • turnip
    • 13
    I have a pinging sound from the front springs when moving off from rest or occasionally over bumps . The noise seems to be from the springs moving in their seats - if I lift the front wing up the noise occurs . Any idea how I can stop this as it is rather annoying ...
    top mounts mate be my bet.
    • turnip
      • 13
      pinging springs
      Top mounts replaced about 3000mls ago and any susp joints that needed doing , plus all dampers . Noise is definately spring related - any other ideas ?
      • Knight Rider S4
        • 3541
        Make sure everything is tight
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • HPmuirt
          S2Forum April Fool
          • Apr 2005
          • 3014
          The noise is usually caused by the top mounts causing the springs to turn on the lower spring plate.
          If the top mounts are new and OK, then it is likely that the spring was not seated properly when the top mounts were installed and the base of the spring is not resting against the stop. This can still make some noise even with new top mounts (well it did in my car until I rotated the spings back to the stops).
          Just my two penneth
          Cheers n
          Si
          Subtle mods here and there
          2011 A5 3.0 TDi - Lava Grey
          • Matt_D
            • Dec 2004
            • 515
            I had this on mine, i thought it was the topmounts but i found out the inner slotted nut on one side had come undone.
            It might be that causing your problem ?
            '95 ABY Avant - Sold
            '98 B5 S4 -MRC400+ = 464ps 741nm
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              Yes. Make sure the retaining nut is done up tight. I've seen this too many times. Use a 'special' tool.
              SS
              • BrianSmith_S2
                • Jun 2005
                • 1342
                • Home: Northern Ireland Current: British Antarctic Territory
                Worn DROP LINK . I had exact same noise on mine and it had begun to bug me last few weeks . Suspected top mounts as most others (year old) causing the springs to move on steering lock.
                However, on investigating, found very excessive play in a lower ball joint of one drop link assy. this attachment to the RS2 FARB would give on full steering lock and cause a twangy clonk
                Replaced both drop links (not too expensive) and easy to fit, and the noise has gone away, and car feels sooooo much together and precise again.
                Brian
                • turnip
                  • 13
                  Cured !!
                  Thanks for your suggestions - got a chance to check things out today as I had the wheels swapped front to rear . Although the springs felt as is they were against the stop ( ie the tab on the spring seat base) when twisted , I tweeked them a bit and the noises have disappeared . I guess they may come back but for now the silence is wonderful .
                  • pastures16
                    • 2058
                    i had this in my old coupe gt many times it was the pig tail at the top of the spring had snapped check it out mate
                    94 s2 avant
                    aoc member 1116
