Vibration from driver side front wheel
  • UrS4Eben
    • Apr 2007
    • 128
    • Home: South Africa Current: United Kingdom
    Hi guys,
    I was hoping you could shed some light on a peculiar problem that I have been having with my UrS4 Avant.
    Basically its something like this:
    When braking or pulling away I sometimes get a "click" from the driver side front area(suspension or wheel).
    I also get a bad vibration from this side when I accelerate to about 80mph but goes away when I slow down again. I can feel the vibration through the steering wheel.
    What do I need to look for to diagnose these kind of issues?
    PS I dont reckon it is bearings as I cannot seem to find any play when i tug on the wheel while its up.
    Thank you in advance.
    Eben
    '92 UrS4 Avant
    www.olddubs.com
    www.expatsa.com
  • volcano rs
    • Jun 2005
    • 2265
    probably anti rollbar bearings
    • UrS4Eben
      • Apr 2007
      • 128
      Does anyone have a picture of them? Are they rubber bushes?
      '92 UrS4 Avant
      www.olddubs.com
      www.expatsa.com
      • Azman
        • 3205
        If by click you mean a bang when pulling away or braking, hard I mean, try reversing with full lock. If you still get a bang or 'click' get under the front end and tighten everything up!!!!
        Meaning lower ball joints, ARB links and caps(which are onto the subframe), anything and everything that can be thightened do it!!!!!!
        I had the same a while back and found going under the front end with a spanner and making sure everything was tight as a nuns c**t (sorry) resolved the problem. A few bolts were loose only by half a turn mind but still loose!!!
        Dark Grey Avant
        RS2 FARB
        Alloy Subframe Bushes
        • UrS4Eben
          • Apr 2007
          • 128
          Out comes the spanner... Thanks I'll try that out and report back....
          '92 UrS4 Avant
          www.olddubs.com
          www.expatsa.com
          • archiboy24
            • Sep 2003
            • 286
            Likely a link rod or ball joint. The link rod links the ARB to the strut housing. Cheap and easy fix.
            Ben
            Calgary, Alberta
            Canada
            1991 CQ e//S2 w/ RS2 spec 3B 20vt
            Panther Black Metallic
            www.moda-architecture.ca
            • UrS4Eben
              • Apr 2007
              • 128
              Is that number 1 in this picture?
              '92 UrS4 Avant
              www.olddubs.com
              www.expatsa.com
              • archiboy24
                • Sep 2003
                • 286
                Hmm. Not sure. I didn't realise you were talking about the urS4 which is a different set up than the Coupe.
                Ben
                Calgary, Alberta
                Canada
                • UrS4Eben
                  • Apr 2007
                  • 128
                  LOL thanks anyway... Anyone else that can tell me which parts to look at?
                  '92 UrS4 Avant
                  www.olddubs.com
                  www.expatsa.com
                  • UrS4Eben
                    • Apr 2007
                    • 128
                    Uhm... yes it was nr1 ... the ball joint is completely F^%^%$ed
                    '92 UrS4 Avant
                    www.olddubs.com
                    www.expatsa.com
