diff mounts
  • Dan_s2_coupe
    • Aug 2006
    • 482
    diff mounts
    Found that i have a bit of play in diff mounts just wondering weather i should buy genuine whic are 20quid each or if anyone knows of any poly bushs 4 them
    quite a lot of play
  • s2driveruk
    • 12696
    bl**dy hell they look shot?
    I think just replacing with oem will be tight enough, anything else will transmit noise and vibration into the cockpit and then stress the next weakest link rubber wise.
    I think the mounts allow a small anount of up/down/side movement but not that much
    1992 3b S2 Coupe
    • Dan_s2_coupe
      • Aug 2006
      • 482
      Ok ill go 4 a pair of oem 1s then
      • Jenks
        • 261
        diff mounts
        Corey is currently offering some slightly uprated and some very uprated versions of these mounts diff/gearbox and also engine mounts. I don't know how to link to the thread in my reply yet and frankly I'm too tired to balls it up by trying but if you use the search facility and type in 'street density' the relevant thread should appear.
        Also worth noting I have been told today that Corey is currently on his hols and won't be back until monday. Hope this helps.
