Hi everyone, just hoping for a bit of input...... was driving the car (its an ABY) when a stange noise began when turning the steering wheel - a sort of whining. Then the autocheck kept displaying the (!) symbol, and the brake pedal felt a little light.
Not the best set of symptoms to occur then you have just told your passengers how reliable the S2 is !After getting the car home and having a look under bonnet, there was a lot of green power steering fluid coming out. There was some on the underside of the bonnet, all over the top of the reservoir and the screw top and the wires for the sensor. Firstly are the braking and power steering systems linked, or have I got several problems to sort ?
Im thinking that the leak might be coming from the screw cap, and the electrical connector on top. I had a quick search of the forum but couldn't see anyone else who had suffered this fate.
The car always displays the (!) symbol about 10 seconds after starting it, but it then goes out and all is well, could this have anything to do with the problem?
Finally, can you buy just the cap, with the float sensor without needing the whole reservoir?
