Wheel bearing noise & Alignment
  • AAH!
    • 497
    • Home: United Kingdom Current: Bhutan
    I had a wheel 4 wheel alignment done a couple of weeks ago and few days later when reversing into a parking space on full lock there was a loud clonk.
    The camber adjustment nuts on the n/s front wheel had come loose. Although I didn't realise this until it took it to a new alignment place a few days later.
    Since having everything tightened up and a 2nd alignment done I am getting some wheel bearing "moan". The noise is a little intermittent but most apparent going in a straight line at a constant speed, disappears when breaking, etc. However it did settle down on the second half of a 300 mile drive over the past two days. (The bearings are only a 14 months old)
    Could a bad alignment cause the wheel bearing to moan or might driving around for a few days with the camber seriously out have damaged the wheel bearing?
    Angus
    formally RS2 +
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    It sounds like it might have caused some damage. The clonk you heard may have hammered the bearing.
    It sounds like you had a lucky escape too. If the lower ball joint had broke loose from the wishbone....
    You'll know not to use that alignment place again.
    SS
