Do you have a clunk when turning?
  • UrS4Eben
    • Apr 2007
    • 128
    • Home: South Africa Current: United Kingdom
    Hi guys,
    I asked about this noise when turning and the vibration on my UrS4 some time ago and I put it down to the driver side front wheelbearing that needs replacing. So i got the bearing yesterday from GSF. Wanted to have it fitted this week.. Drove out of Tesco's this afternoon and the cluck was quite loud out of the turn....
    5 meters from my parking space at home, heard a noise and then I heard the tyre rubbing the back of the wheelarch... Just parked it and had a look at what happened.
    The bottom balljoint from the drivers side track control arm completely popped out and destroyed itself..... so this lets the wheel move freely front and back.. not good......
    Now I want to know... can just the balljoint be replaced or do I need to buy a whole new track control arm with balljoint? what should it cost me? is the partnumber 4A0407151?
    Please help
    '92 UrS4 Avant
    www.olddubs.com
    www.expatsa.com
  • Pembo
    • Aug 2004
    • 295
    You have the correct part number just check which side you need against part number.
    Approx 200 Euros from Stealers (£130 UK pounds)
    German Sweedish French good in UK their part number 42225 is Left Hand 42226 is Right hand both £36.00 UK pounds.
    Try www.vagparts.com
    Hope all is OK with the car.
    Wheel bearing don't clunk! they just rumble. Botton ball joints (track control arm), steering tie rod ends and Universal joints (Steering UJ's) all do.
    Pembo
    quattro - Original 4WD rallying
    Rally Car photos
    • sherv
      • Apr 2007
      • 315
      Hi, I've just had my rs2 in for new exhaust and springs and asked the guy to check for play in the near side wheel bearing as i sometimes get a whurring noise. When I pull out of my drive on full lock and accelerate it's almost like the wheel shifts a little and it makes a small clonk noise. I've been told it is play in the steering rack and is fine??!! There was no play in the bearing and when springs went on he noticed nothing wrong with the ball joints etc......?!
      Sherv (Dan)
      S5 with all the goodies
      SOLDRS2 Volcano Black RHD 55k
      • UrS4Eben
        • Apr 2007
        • 128
        Thats exactly what I had... you wont find any play on the bearing either and it even passed MOT like that.. It must be cos the ARB and coil keeps it loaded and it will only "shift" like you say when driving and cornering... Your symptoms are EXACTLY the same but I'm not sure if the RS2 susp layout is the same... Have it checked out before your have trouble like I am having now, to find someone that can recover a car with collapsed front susp...
        '92 UrS4 Avant
        www.olddubs.com
        www.expatsa.com
        • sherv
          • Apr 2007
          • 315
          tricky one as Pembo said it could be something else other than ball joints (track control arm)???!!! Will phone and see if he can go out with me so I can show him what happens. Will let you know. Cheers for the help. I'm driving through Europe next week and don't want to get stranded of course.
          Sherv (Dan)
          • UrS4Eben
            • Apr 2007
            • 128
            '92 UrS4 Avant
            www.olddubs.com
            www.expatsa.com
            • UrS4Eben
              • Apr 2007
              • 128
              Better safe than sorry I'm driving to Slovakia and back on the 16th... thank God this happened now and at "parking speed"....
              '92 UrS4 Avant
              www.olddubs.com
              www.expatsa.com
              • sherv
                • Apr 2007
                • 315
                popping up to take the guy from the garage out tomorrow at 10am. Will let you know if it tuns out to be similar/same? Didn't do it this mornig when I just went out. Doh!
                Sherv (Dan)
