S2 front track rods onto UR????
  • The Chef
    • Jan 2007
    • 129
    Please can some one who has done a 3b 20v into a WR UR quattro tell me which set up of track rods arms etc they used to get it all working?
    Story so far is i have the 20v in with the s2 gear box. The S2 front legs are fitted and drive shafts are in (again the 3b ones) as the URs are a different fixing on the ends.
    The UR track rod ends dont fit as the ends are different sizes to the holes in the S2 legs.
    Question is so what did you use?
    Thanks in advance as Im desperate to get this sorted..
  • jogi730
    • 2335
    Think Pete at quattro Corner may be able to help you there.
    Give him a call.
    Chris
    Audi 90 quattro (Typ 85)
    20v turbo conversion
    • Jaap
      • Oct 2003
      • 258
      Just drill the hole 1 mm bigger
      • sal_s2
        • 1287
        Or use the s2 arms complete with the bracket that bolts onto the steering rack
        • Jaap
          • Oct 2003
          • 258
          S2
          I also did use a S2 subframe and control arms from a S2.
          Just the strud is original Urq.
          Only need to weld the flances for the ARB on the Strud (connectingrods)
          • The Chef
            • Jan 2007
            • 129
            Thanks a million... The holes will be drilled... Hopefull I may get some time to go and sort it before It comes back to get wired up
