were there any major mechanical differences between the audi 80 and the s2? For instance, I assume springs and dampers were different, but did the s2 run the same track and geometry?
the brakes were obviously different, but were the mountings on the suspension struts the same?
I assume the shells were similar in that headlights, bumpers etc are all interchangeable? same with interior trim?
were the s2 gearboxes normal 80 quattro units, or were they fitted with a different casing or ratios?
cheers
cheers
Or if not, where could I get some for the 2.8??
