My car failed its MOT because...
"Front (both) macpherson strut has excessive movement at the upper attachment [2.5.A1c]"
As per usual my friend Kenny was collared to have a look (I know sh*t all) and after removing the plastic caps, pushing the car from side to side, jacking the car up and pushing it again was puzzled by the diagnosis.
From the horse's mouth (sorry Kenny)
"With the car on its wheels I yanked the body sideways and saw no movement. I also yanked the top of the shock from under the wheel arch and saw no movement.
With the car jacked up I yanked the wheel back and forth and yanked the shock/spring and saw no movement. Twisting the spring did show some rotational movement of the top mount from within the engine bay. Is this normal?
As I jacked it I believe I did see some vertical movement of the mount from within the engine bay as the wheel started to hang down, but it was dark so I am not 100%. Is this normal?"
If it does still sound like there may be a problem, I'll need to take it somewhere to get it looked at - can anyone recommend a good mechanic who knows their S2s in North London?
Cheers ears
Cheers ears
