WHAT type of rear bushes should i go for?
  • john881000
    • May 2004
    • 598
    hi all
    need to replace rear wishbone bushes on my 90 quattro sport(B3), for MOT
    WHAT WOULD YOU RECOMMEND?
    normal street driving ...........with a little fun too
    std/or another make
    where to get them
    thanks for your thoughts
    cheers
    john
  • Flat on my back
    • Jan 2007
    • 2449
    Stiffer...
    OEM if you want comfort, but they will need fitting with a big press...not really a diy job.
    Powerflex can be fitted diy with a little time and effort, do the top mount as well.
    If your going for a full refurb, get all the bits you need eg shocks/springs, brake lines, discs/pads...and do the job in one go or you'll be under the car once a month just after pay day with the new bits!
    Carlos.
    • Rusty
      • 18953
      Have a set of OE wishbone bushes for sale if you're interested. They were bought from VAG parts a year ago.
      • john881000
        • May 2004
        • 598
        hi mate
        good advice on all above
        suspension is generaloly good on her at moment..................bushes here nabbed cos i got inspcter at work to be hard on car......he said they would advise on them.not fail yet ....but i doing bearings and hub swop so i thought i might as well do them nw,,,
        just need to get car running................so i can strip my red avant for my project car.......
        looks like POWERFLEX is way to go
        cheers
        john
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Don't get squeeky Powerflex bushes when Superflex are available.
          It's just a shame they don't do the larger bushes for my front subframes. I had to fit Powerflex crap.
          SS
          • Technogym
            • Dec 2004
            • 200
            • Country: Norway
            I have installed powerflex all over the car, and I keep hearing the warnings about squeeking and stuff, but I have been driving with mine for two years now, and not a whisper of a sound, so I really have to ask the question if people are mounting them iaw the instructions? Or they are stated as so easy to assemble that everyone with a spanner try to make them fit, but really not have the skills or knowledge to do it right? Copper grease on the bolt, copper grease the trunnion, teflon washers on each side, bolt on and torque. And you have a rock steady handling and not that extreme increase in noise as many states. If You already are putting 18" or maby 17" with a normal quality tire they will make more noise then the OEM bushings can put to silence.
            So from I will definatly give my thumbs up for the powerflex, and when remember: if You have a car with worn bushes it wont help to change only half of the worn ones, the the new ones will be destroyed in weeks. So a good advise is to check the subframe, engine, GB and diff bushes as well!
            Vegard
            • Flat on my back
              • Jan 2007
              • 2449
              Nah nah
              No trouble wiv mine either!
              That's 2 to 1, we win!
              Carlos.
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                It took 3 people and a large mallet to fit my front bushes. Those washers are a PITA, and the bushes still squeek, copper grease or not. Superflex bushes were push fit, so took 5 mininutes to fit and no problems since.
                SS
                • Flat on my back
                  • Jan 2007
                  • 2449
                  Eh....
                  Somethigs wrong there.
                  All the PF bushes i've used could be fitted with firm hand pressure and no more? Even the steel inner sleeves.
                  Went for PF cos the dealer is just down the road from me.
                  Carlos.
                  • Technogym
                    • Dec 2004
                    • 200
                    • Country: Norway
                    Agree with flat.
                    The PITA is to get the original bushes away and throw them as far away as You can!
                    But when they are all gone and the bush seats are thoroughly cleaned and free from rust and debris from the old bush it was a handpush job to make them fit. so it sounds strange. And of course as i mentioned it is no use to change to pf if the rest of the bushes on the car is gone, then they will be broken and probably squeek in just days.
                    vm
                      Personally if you are going for uprated go for superflex if you can, I had to change the bushes on mine 3 times while powerflex redesigned them each time to stop the sweaking so I was a guinea pig for that one. quite well practiced at changing them now though
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        Originally posted by Technogym
                        Agree with flat.
                        vm
                        All other suspension bushes have been replaced with either new OEM, polyurethane or alloy, so the problem isn't there. The wishbones were clean before fitting the new bushes too, so the problem isn't there either.
                        The bushes themselves were indeed push fitted by hand as normal. The problem was the washers. There just wasn't really any room for them, and they don't locate anywhere apart from on the bolt. Hence two people to hold a pair of washers each and a third to whack the wishbone into the subframe.
                        The icing on the cake was to discover a short while later that the bushes squeak and creak, unlike the Superflex rear wishbone bushes that were fitted shortly before, with no problems I might add.
                        If anyone knows of a good replacement for the forged front wishbone bushes, then let me know. I get a horrible reminder of those crap Powerflex bushes every time I hear Bo creaking around in his car.
                        SS
                        • Skaala
                          • May 2007
                          • 148
                          • Country: Norway
                          I have black powerflex in the rear on my RS2, and I have never heard a squeek or noise from them. They're firm, but not uncomfortable. It was a dream on the autobahn and on the Nordschleife.
                          2007 Audi Q7 3.0 TDI S-line____2003 Audi A8 4.2 Quattro____1994 Audi RS2 2,2T Avant____Audi Quattro Experience____Audi Sportscar Experience
                          Protected movement - with quattro
                          • s2avant
                            • 2426
                            I've got black powerflex front and rear on my avant and don't get any squeaks. Only issue I have is with one of the rear wishbone bushes falling apart but powerflex are replacing it FOC.
                            Ben
                            • s2driveruk
                              • 12696
                              quick question, powerflex/oem/supaflex...what is the correct torque value assuming the arm is loaded correctly weight wise?
                              David
                              1992 3b S2 Coupe
