Hydraulic system flush
  • s20ale
    • Aug 2004
    • 476
    Whats best procedure for flushing hydraulic system ie what hose is best to dissconnect,
    after searching variuos threads on this subject can't seem to find any info on actual flushing.
    I did see a post mentioning flushing steering rack as well ,can this be done at same time.
    Any help on this would be appriciated thanks
    i need to do this too - after seeing the colour of my fluid when removing my broken bomb.... my god. it looked like bisto
    drained as much as i could via the return hose from the top of the bomb, but guessing there must be at least another pint or so in the pump, lines and the rack. I want to give it a thorough flush to remove all the build up crud that is surely in there.
    • Skaala
      • May 2007
      • 148
      • Country: Norway
      I'm going to do it as well...
      2007 Audi Q7 3.0 TDI S-line____2003 Audi A8 4.2 Quattro____1994 Audi RS2 2,2T Avant____Audi Quattro Experience____Audi Sportscar Experience
      Protected movement - with quattro
      • s20ale
        • Aug 2004
        • 476
        Mmmmm good response to that one then!!
        C'mon lads a few people need to do system flush so a bit of would be good?
        all this knowledge and not one reply, someone must have done this before.
        • Cullam3n
          • Aug 2007
          • 993
          • Home: United States Current: United Kingdom
          I cheated, had my garage do it.
          You can cycle through the pump by hand though, just keep turning the pulley around.
          • s20ale
            • Aug 2004
            • 476
            I was thinking more of disconnecting A hyd hose somewhere running engine and keep topping fluid up.:mischeif:
            Maybe this is not possible for thyn is the question of what hose ??
            • s2_bo
              • Oct 2005
              • 6067
              Make sure you manage to catch all the fluid though. That stuff satins the road for months. I had a leak in my pump > bomb hose and it lost almost a liter of fluid in 20 seconds. That was 3 months ago and the road outside my house is still covered in splutters.
              91 S2 coupé - RIP
              98 S8 - Luxury barge
              • coupegt
                • Jan 2005
                • 218
                • Country: Denmark
                pump is running high pressure of 6-7 bar AFAIK, so a disconnected hose with running engine might not be the best idea IMO
                  Washing up liquid will shift that mate - get a brush a scrub it good with some persil or something.. then wash it all away - done
                  • s2_bo
                    • Oct 2005
                    • 6067
                    no way. the council can do it if it bothers them. Its a good reminder to check your fluid levels AFAIC
                    91 S2 coupé - RIP
                      This stuff is pressurised to 140bar guys - so do NOT open the high pressure pipes for drainage.
                      Best way to get rid of most of it is by dissing the low pressure hose at the bottom of the hydraulic reservoir. Tis nasty stuff alright so its wise to be green and gather it carefully.
                      Might need a couple of goes with the engine run up once or twice, making sure you go from lock to lock on the steering wheel to purge the system of old stuff.
                      Paul
                      • s2driveruk
                        • 12696
                        there is a how to on 20v.org IIRC....
                        1992 3b S2 Coupe
                          you mean this?
                          ***I accept no reponsiblity for retina damage from clicking the link ***
                          doesn't really make it clear how to drain the system though.
                          • s20ale
                            • Aug 2004
                            • 476
                            Paul
                            Exellent cheers Paul i'll give it go noticed my system is full of the red stuff.
                            So needs flush ASAP,Hoping theres no permanant damage to system.
                            Previous owner used to service aircraft at Gatwick !!!Hummmm
                            • GT500
                              • Jun 2006
                              • 2181
                              Red stuff will be ATF, muppets seem to like putting in Audis , both my cars came with red stuff in!
                              Lasting damage will be all hoses,pump seals. It rots the rubber. changing to the green mineral oil will help but it carries on rotting the rubber even after changing the fluid a few times. Steering wrack seems to hold up better, not had a problem yet!
                              muppets stick to working on Fords please!
                              Rob..
                              87 UR 20v ABY
                              97 S6 Avant
