side photo of RS2 on bilsteins?
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    does anyone has one to share?i know maRS2 is the best for this,but he is hard to contact these days.I would like to see the looks as it is said that sports bilsteins on OEM springs tend to raise the car a bit.just want to see how it looks!
    thanks
    Vasilis
  • GT500
    • Jun 2006
    • 2181
    Hi Vasilis,
    Its not just the "look" that will change with it Jacked up at the back. It will change the corner weights, throwing more weight forward.
    Will make it more tail happy when it lets go. so will the softer sprintline shocks.
    Drift car?
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      no im planning to make the conversion to lower the rear s4 bilstein shocks.There is a controversy about whether there is 13mm or 20mm lower so i had both measurements made.I just want to see a photo with them on,both front and rear so that i can see if the car is lifted slightly as it does usually with bilstein sports
      • urS6
        • Dec 2007
        • 35
        • Country: South Africa
        RS2 on Bilsteins
        Hi
        I have just ordered the B6 Sport front & rear Bilsteins for my RS2. Now that I think about it, it did seem like my urS6 did look a bit raised when I put Bilstein sports on
        Was this the right choice on OEM springs. Should I have perhaps gone with the B8 Sprint rear shock - this was for a lowered car?
        Is there a way to retain the standard ride height with the Bilstein Sports?
        Thanks
        1995 RS2 - old school handful ~ for fun!
        2004 allroad 2.7T now mine
        2008 GTi MkV DSG - was mine, now hers!
        1995 urS6(m) - sold
        Jozi, RSA
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          since i got it done already,here is a before pic
          in this i have OEM shocks BUT all gone
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            after:
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              i would say slightly higher,but in a week or so,they will sit a bit more
              • urS6
                • Dec 2007
                • 35
                Mmmm...I have to say that from the before and after pics it is difficult to see.
                So...what is the handling like? Does the backend stay tucked in when you change direction quickly? I assume you are on standard ARBs?
                1995 urS6(m) - sold
                Jozi, RSA
                • Lloyd
                  • Apr 2006
                  • 1559
                  Urm, I think the car will not change ride height with change of dampers. Changing spring length or height of platform will change ride height.
                  RS2+ (now sold...)
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    well,ride is a tad stiffer than OEM(but then again my oem setup was shot lately so i cannot say for sure),it feels like less roll on turns and i cannot say about the rear being the bilsteins only or the RARB which i changed to neuspeed im afraid.I can say that the car feels more neutral and has a tendency to push the rear out of position on abrupt turning which is entertaining i might say!!!
                    The car seems just 1cm higher between the 2 photos.Thats all.And it also may go away.
