Removing the Undertray
This topic is closed.
This is a sticky topic.
    Get the car SAFELY up on axle stands before attempting this... Though it can also be done with the front wheels still on.
    1 - Remove 10mm plastic nut where undertray is secured to inner wing (each side)
    2 - Remove quick-lock screw where undertray also attaches to inner wing (each side)
    3 - Under the car, remove the three quick-lock screws at the rear of the undertray where it attaches to a bracket on the subframe.
    4 - Using a large screwdriver at the front of the undertray, prise out the mahoosive plastic clip which locates it on the bumper.
    5 - Slide the undertray towards the rear and away it goes.
    No need to keep this an open thread... I'll maybe add a photo or two to finish it off.
    Paul
