i'm planning a complete underbody/suspension & Drivetrain overhaul on the CQ, aiming to have all the parts ready for a big changeover at some point this summer...
I'm planning on buying up all these parts on the cheap and refurbing and rebushing them and then swapping all the parts over at the same time - keep the old girl going for another 10 years at least hopefully
I may fit some uprated bits at the same time, budget permitting
I assume the rear struts, rear bearing housing/hub carrier, rear track rods, rear subframe, rear diff, rear arms, rear drive shafts, prop and centre bearing are all common between the CQ and the 3B/ABY (except the prop with the ABY)?
I know the front S2 struts are "fatter" than the CQ ones - are they a straighty swap?
If i manage to find a set of S2 hub carriers/bearing housings with the 5 stud hubs still attached, will this be a straight swap also?
