H&R guarantee?
  • s2driveruk
    • 12696
    H&R guarantee?
    Seems my H&Rs had sagged slightly on the drivers side rear and/or drivers side front. No obvious handling issues but it doesnt sit right on a flat surface and its finally annoying me
    Suprised this has happened, they have been on the car for about 3yrs but mileage wise they have done something like 15k miles max.
    Anyone know who is stocking them as i want to get it sorted but also what kind of guarantee h&r have?
    David
    1992 3b S2 Coupe
    this is a bit worrying! I thought H&R were the best of the bunch
    Makes me wonder if my rear springs are sagging too, the rear end seems to sit about 10mm too low
    • sherv
      • Apr 2007
      • 315
      one side of mine at the rear is a good 10mm lower than the other but I do think this was the case before I put the springs on. Some cars do just sit like this??!!
      Where I got mine from this year http://www.orange-tuning.com/shop/pr...oducts_id=1399
      Sherv (Dan)
      S5 with all the goodies
      SOLDRS2 Volcano Black RHD 55k
      • s2driveruk
        • 12696
        hmmm cant say for certain mine wasn't before I put the h&r's on but i'm pretty sure it wasn't. Might have to take them off and see if they are only different when compressed or if the sag is evident even uncompressed
        1992 3b S2 Coupe
        • Flat on my back
          • Jan 2007
          • 2449
          Get the car corner weighed with a full tank of fuel and one bod in the drivers seat, bet you the measurements are different from one side to t'other.
          Carlos.
          • s2driveruk
            • 12696
            sh*t am I 'that' heavy
            1992 3b S2 Coupe
              • Rusty
                • 18953
                Good oportunity to fit the RS2 H&Rs... :mischeif:
                • s2driveruk
                  • 12696
                  remind me on the RS2 setup on the coupe Andy.....? Whats the advantage/cost etc
                  D
                  1992 3b S2 Coupe
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    D
                    Would you not have to change to avant struts on the rear? the same as the 80 salon?
                    Chef
                    • s2driveruk
                      • 12696
                      hmmm see that was my thinking as the back end of the coupe is essentially the same as the front minus the connections for the tie-rod ends for the steering IIRC
                      1992 3b S2 Coupe
                      • Flat on my back
                        • Jan 2007
                        • 2449
                        Ooooops, didn't mean it that way...
                        Maybe its time yawl S2 owners did some measuring and compared results, eg centre of hub to edge of wheel arch?
                        Carlos.
                        • Rusty
                          • 18953
                          Nope, RS2 / Avant rear stuff is completely different to the coupe and saloon. I looked into this back in the summer before my money went into bricks and mortar.
                          H&R RS2 front springs on front and rear, no messing about required as the front and rear struts are nearly identical. From memory S2_Ant had standard front H&Rs front and rear and H&R offer this as an alternative to the progressive rate rears. Also, having measured the front and rear standard S2 springs and making a few assumptions about material and temper, the rears are stiffer than the front by approx. 5% so front and rear springs are close (I must stress that this is theory and not a true measurement of the spring rate).
                          My thinking was that with front RS2 springs front and rear, any understeer caused by the relatively softer rear springs can be dialed out. However, these are what S2Avant has on his car and they are STIFF, he's experienced some interesting handling charactistics with a car this stiff . There's more complnce in the tyres on the 18s than the springs
                          I spoke to Pete at QC about sourcing front RS2 springs and he was able to from his supplier. Also cost approx 50% more than the standard stuff due to rarity.
                            That does sound very stiff indeed... Oh and I'm glad that s2driveruk had even more turkey at chrimbo than I did - LOL.
                            Paul
                            • s2driveruk
                              • 12696
                              i wouldnt mind if it WAS the turkey but oooooh no, those damn salt & balsamic vingear kettle chips and real ales
                              Almost sounds too stiff for me.....i didnt mind the performance or feel of the original H&R's, they were bone shaking enough on the wrong surface lol
                              1992 3b S2 Coupe
