Any ideas on the quick.....
  • jubjub
    • Nov 2003
    • 1239
    Just been shopping, when i got back to the car there was a spot of something on the floor under the car, right in the middle near the front. On inspecting it turns out to be hydraulic fluid,so any ideas on were this may be leaking from? Obviously i will get the car up in the air tomorrow,but someone may be able to hazard a quick guess now.....
  • Doug_RS2
    • 3847
    I'm assuming you don't have an undertray?
    could be the silver flexi hose that goes across the front of the radiators - I have had one break on me - just feel for oil and you should find it.
    • jubjub
      • Nov 2003
      • 1239
      Just been out and checked.... it is not directly from the metal pipe, but at the left it joins to a hose somehow( seems to go inside?) This looks like the culprit....What part is that? Oh yeah, no undertray....
      • Doug_RS2
        • 3847
        I think it goes straight to the power steering pump at that pont - check to see if a hose is split or the clip holding the rubber hose is loose
        • jubjub
          • Nov 2003
          • 1239
          I'll check that tomorrow....
