If you get the front ones which are only made as 'sports' and then source a sprint rear shock set,then your rs2 will most likely look like it is sitting lower @ the rear.The only way to make it sit lower in genereal,is to match the sports shocks with H/R springs.
why do you want sprint shocks anyway?If you are going to use the OEM springs,then bilstein sports are the shocks that should be used(according to bilstein that is)
excactly then,if you are not buying lower springs of any kind,then the shocks should be sports,not sprints.otherwise the ride will not be as good since bilstein manufactures the sprint series to go with lowering springs.
Bilstein names the sports as sprints in the US and the sprins as HD in the US hence the confusion
To conclude,anyone that has gotten the set of HR+bilsteins has used the codes you already have,meaning that they have used the sports series of shocks which basically what will happen is run the shocks down sooner as they have smaller movement due to the lower spring.Even if you do find a rear shock in spring category to accomodate the HRs then you are still stuck with sport shocks for the front,as bilstein never made a sprint shock for the front for the S2/RS2
