RS2 Weighbridge Results....
  • Lloyd
    • Apr 2006
    • 1559
    I was passing our local weighbridge this morning, had a few minutes spare so decided to get the car weighed up. Was always interested to know exactly what the total and split axle 'wet' weights were for the car.
    The car had 3/4 tank of fuel, half full washer bottles and spare wheel. No luggage/people in the car on weighing.....
    Total: 1640 Kg
    Front Axle: 940 Kg
    Rear Axle: 700 Kg
    So, add a driver and passenger and it's one seriously front end heavy car! Nothing we didn't already know but pleased to get some firm data in any case.
    RS2+ (now sold...)
  • Bram
    • Aug 2006
    • 2582
    Good data! Thanks, Let's go for a rear-engined RS2 then
    • Keeper of The Kitten
      • Dec 2003
      • 2317
      57% F
      43% R
      That's front heavy but really not too bad I would say, given the position of the engine in the package! I am intrigued to know how a coupe compares - the coupe has a shorter tail so it might be more biased to the front.
      Martin Cutting
      • Rusty
        • 18953
        I'd always wqorked on 950kg on the front axle so pleased that I wasn't too far off! That's a mk.2 golf GTi on the front wheels
        It's amazing that with all that weight these cars are so fast!
          • Dec 2003
          • 2317
          But the overall weight of the coupe is less, so that's most likely less on the rear and the same (ish) on the front? And five speed box is lighter than six speed, which conversely removes some weight off the front (proportionally more than off the rear I would say because of it's position).
          Definitely taking as much off the front of my car as possible! Need to counteract fitment of bigger brakes anyway...
          Martin Cutting
            I had weights on my Coupe from an MOT test.... Darned if I can find them though. I maybe posted it on the forum before.
              Gotta love that search function
              Weight on front axle was 1054kg
              Weight on rear was 715kg
              Now OK both me and the tester were onboard and we've each had a few too many pies but that is shockingly heavy.
              Reckon on 160kg mass of me and t'other block and guess half a tank of gas for this split in round numbers -
              Front 60%
              Rear 40%
              Thats a 6-speed ABY Coupe with Aircon. Hefty enough
              • stiglet
                • Aug 2007
                • 1264
                I thought MOT testers used maximum permissable axle weights??
                I think the S2's weigh about 1500kg in total with one passenger???
                  In NI, the test rigs weigh the cars - I got figures from their display during brake tests.
                  • stiglet
                    • Aug 2007
                    • 1264
                    Ah right! i stand corrected. F**k me thats heavy!!! Could this be the one bragging point for the much lighter 20v owners???
                    • mcandmar
                      • Apr 2004
                      • 5118
                      You bet it is
                      91CQ20v - Gone to a new home
                      93UR-S4 - The Magic Carpet
                      94S2Bus - The Emerald Express
                        I'll check what it is when i'm at my dads next because that weighs the axles as doing the brake tests
                          • Dec 2003
                          • 2317
                          That's stupid heavy!!!
                          Exactly how much do you and the tester weigh Paul?!!
                          Martin Cutting
                            I'm about 80kg (slight podge on)... The tester had larger podge and more height (not difficult)... Gotta say 180kg between us approximately.
                            • stiglet
                              • Aug 2007
                              • 1264
                              i knew the s2's were heavier than other coupes but i didn't realise the difference was so big. I guess when you take into account the turbo, intercooler, air con compressor/condensor, bigger stronger gearbox, it really adds up!! I seem to remember the series 2's weight something like 1250kg, the series 3 non s2's weight 1350kg (kerb weights).
                              The performance of these cars on both straight lines and wiggly bits is outstanding considering.....
