Improving handling
  • bertman
    • Apr 2007
    • 1173
    • Current: United Kingdom
    Improving handling
    Would like to improve the handling on the ol' girl,whats the most cost effective way of improving it without breaking the bank(the bank has nowt in it)
    And I do not want to drop the height too much
    Now where are those cable ties
    Rob
    Ragussa green avant RS2+ spec
    Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
    Audi coupe gt-slow as hell but loads of character-sold
  • iain1067
    • 984
    New shocks, bushes and alloy subframe mounts
    • BRY
      • 3755
      And an alloy motor.
      • bertman
        • Apr 2007
        • 1173
        Originally posted by BRY
        And an alloy motor.
        Got any for sale
        Rob
        • Rusty
          • 18953
          Neuspeed RARB upgrade if it's tight already, new shocks, bushes & balljoints if it's not.
          • bertman
            • Apr 2007
            • 1173
            What's the going rate on one of those suckers??
            Rob
            • Acidburn
              • 13459
              Rs2 farb as well to go with the rear one.
              • Rusty
                • 18953
                Only if you've got ÂŁÂŁÂŁs to spend as they're not cheap anymore!
                • bertman
                  • Apr 2007
                  • 1173
                  What about changing out the springs only for an improvement.
                  And what is recomended,H&R?
                  Rob
                  • Al Wyn
                    • Nov 2006
                    • 3746
                    You can have a try with my H+R springs if you like buddy
                    S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
                    • bertman
                      • Apr 2007
                      • 1173
                      Thanks mate might take you up on that
                      Rob
                      • bartolomeus
                        • Jan 2009
                        • 1475
                        • Country: Romania
                        Bringing an old topic back to life...
                        What would be best way to improve the handling for an S2 Coupe without burning your pocket?
                        All the topics handling this info are so old... So I've thought to ask again...
                        - other front and rear anti roll bars but what make and model? I've searched now for some Neuspeed RARB and cannot find available anymore;
                        - solid subframe bushes;
                        - poli wishbone bushes;
                        - sport suspension;
                        can somebody with experience share any other suggestions?
                        • rynaqui
                          • Mar 2012
                          • 2752
                          • Country: Malta
                          So far this is what I've had, KW V1 suspension or better. Whiteline RARB on stiffest setting but this is very harsh and a front RS2 FARB but is not really necessary IMO.
                          New drop links (stabilizer links - RS2 front (Thicker) and S2 coupe Rear)
                          Wishbone bushes - Superflex or other polybushed
                          Subframe bushes
                          Renew ball joints and tie rod ends
                          Diff hanger bush
                          Refresh the under mounts, diff, gearbox and engine with OEM (I have not tried aftermarket here - takes around three-four hours)
                          Front snub mount (Rusty on here is having a really nice set made up soon). This should reduce engine movement a lot.
                          There is also the option of having wider tyres at the front as well
                          1996 S2 ABY Silver
                            Best bang for buck IMHO is stiffer rear ARB, then poly bushes
                            • Bowie69
                              • Nov 2013
                              • 2675
                              Which one though, on a budget?
                              Ta!
