when changing the front subframe... have got all the nuts/bolts off, except for the 2 that hold the gearbox bushes/mounts in place.. to remove them do i need to drop the exhaust down??
no you do not need to remove the exhaust at all. For the passenger side, you can use a 17mm wrench for the bolt which is easily accessable from the passenger wheel well. And for the 17mm nut on the bottom, just use a longer extension with a deep socket to get at it.
-1990 7A coupe (US)
*s2 front end with rs2 headlights.
*Fiber Images CF hood.
*5 lug converted (s2 front, early a4 12v rear).
*993 TT front calipers, rs2 brackets, SS lines, A8 323mm rotors ,and Ferodo DS2500 Club Race pads.
*H&R springs with Bilstein HD shocks and green HD strut mounts.
*Another 7A on the stand almost ready for boost
-1991 3B 200 20v Avant (US)
*Ben Swann Chip www.gtq.com
*Boge Turbo Gas struts
