Just finally put on the freshly painted front subframe along with new solid mounts and wondered if there is any specific alignment steps i need to go through? I've basically unbolted the wishbones from the subframe so settings would be against the old frame which is not going to be much help.
If there is a set procedure or any advice, would be welcome, fully intending to get a proper alignment dont but want to be sure that the subframe is sat square on.
david
david
which they will be i'm sure.
