Front subframe change
  • Mr.Crossfire
    • 145
    The 3 mounting points are floating, 1 solid. I had both of my subframes off just few months ago. There are threaded metal plates which are floating inside the chassis.
    • s2driveruk
      • 12696
      hmmm wonder if some of mine have binded then? Can you remember which was the solid mount of the 4?
      Ta
      David
      1992 3b S2 Coupe
      • Mr.Crossfire
        • 145
        Unfortunately I don't, but it's clearly visible when you remove the subframe. The solid mount has the threads directly cut to the chassis leg, the floating points have ~30mm hole in the leg and the plate is inside. The plates were loose and easily movable although I think this was the first time the subframes were removed.
