The rear one fits, search forum for neuspeed and the thread by S2avant showing installation
Whiteline also makes one for the Avant, 90GBP including shipping, have just fitted it to mine. Well impressed with it so far ! 18mm and it has made a huge difference compared to the stock S2 Avant one...
But you'll have to PM Corey direct as he's now *persona non grata* in here
FYI...I have just had my standard RARB swapped for an RS4 version....it's 15mm, you can get them quitre cheaply as the RS boys are always upgrading theirs, and it has made such a difference...
It's the same as the Whiteline RS4 bar when I spoke to Awesome GTI, however did you get seperate mounting brackets to the subframe with yours?
Have you got any pics?
I'm leaning to the Neuspeed as I already have an RS2 RARB
How come the Avant RARB comes without a bracket but the Coupe one does? Bit odd. Are the brackets that different?
My understanding is that the Avant RARB stock brackets are suitable for much stiffer ARB's but the subframe flexes a bit which is not "really" desirable though not a real problem. Neuspeed supplies brackets to prevent the flexing of the subframe.
The coupe Whiteline RARB supplies brackets as it's an adjustable set-up with 3 different RARB positions of stiffness.
