While i was doing a oil and filter change this afternoon i noticed that i lost two of my FARB bolts
Now i have a small problem
I have replaced the two bolts that want walkies (these btw were the top bolts on the u clamp, one either side) now these tighten fine the problem is with the bottom two bolts, they keep spinning as you try and tighten them.
I believe the nuts that are spinning are supposed to be welded to the subframe ??
If so what are my options ? Anyone had this problem before ? New subframe time ?
