I have been reading though all the old threads and confusing myself as to what springs i need for an S2 Coupe with Koni adjustables on it? Can someone point me in the direction of what springs i need and where i can get them from?
Thanks
A few useful threads for you. Correct part no. is 29939 VA (front) & HA (rear). You can just got for the VA front and rear but teh back will sit up a bit, I believe Greg_S has this. YOu can also just fit Avant fronts (VA) front and rear or even RS2 VAs front and rear if you don't like your fillings.
Just got a quote off DCdezign and the springs are now £293 delivered! Oh well expensive but from what i have read are worth it. I may try the cobra ones just to see. ANybody else got suggestions on possible springs to put on a coupe
Avant fronts on front and rear. Avant front springs are identical to coupe front springs. Just another option. Just have to ring around for them.
If you put up a wanted thread then something will come up, I got my low mileage HnRs after a tip-off from a wanted thread and paid <£200 for them with some fresh powdercoat, better than new
