@skull23
then there must be some ring or something in the monroe package to fill the gap and hold the insert in place..
the strut is def. 50/55mm in diameter..
'93 Audi S2 Avant panthero black, 412.000km
'94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
'93 Audi S4 C4 Avant, 260Tkm
'88 Audi 100 Avant turbo 44Q
'84 Audi 80 quattro tornado red
We have to clear a few things. What is a strut? Is it the shock absorber insert?
If this thing has to be 50 or 55, it means there are no bilsteins i can use on my car? In the bilstein catalog there are no numbers below 50 for any of the B4 audis. Not even as an oem replacement part...
Bilstein 55mm for the S2 front are F4-PE3-3086-H0 aka PE3-3086.
These are inserts which go into the strut.
Reason: other data
Yes, the diameter of the strut tube which bolts to the wheel bearing housing (So it's called in the family album).
A lot of rust there, you will have some struggle with releasing the cap which holds the insert in the strut tube... If you have no luck with e big pipe wrench or stillson wrench - I made a cut into the cap nut, very carefully not to touch the thread, some millimeters, and then some hits with hammer an chisel in an angle of 45 in the direction of turn... Lots of fun..
i have so many spares at home smiley, i had another competition that one girl crashed (into me), so i will renew them and just swap the whole thing. is the original key for releasing the cap available somewhere to buy?
Spares, very good!
You will find the tool on the bay, its called VAG 2069A.
Other useful tools are VAG 3078 and VW 524 for the slotted nut.
