So...
im dismantling the rear subframe, and i cannot remove the 2 bolts (one on each side), that have the offset washers... on that track control thingy.
how the hell do they come off??
edit: pics:
second issue: the T piece for the rear brake line is stuck in the subframe. has a bolt on it, but the whole piece is turning around. no hole on the other side of the subframe, so i dont think there is a nut on the other side (inside the SF).
so...?
and at the end, a good example of a ruined bush, must have come like this out of the production line:
normal bush:
busted bush:
edit: pics:
so...?
normal bush:
busted bush:
