Knocking noise?
  • rallyejames
    • Apr 2008
    • 129
    Knocking noise?
    Hi there.....Knocking noise from front offside suspension over rough ground?Dont know if you guys have any ideas? but i have replaced the top mounts but its still there
    Many thanks James
    Be the anti roll bar drop links or worn ball joints
    My betting is the anti roll bar drop link
    Also is the spring seated correctly on the strut?
    • rallyejames
      • Apr 2008
      • 129
      spring is seated ok....will check the arb d/l bushes and ball joints,,,,many thanks J
        I'll also bet ARB drop links...... Easy fix - makes sure to renew with steel ones - OEM on the RS2 - not the crappy plastic yins on S2...
        • Rusty
          • 18953
          Me three for drop links...
