Vibration when cold
    Vibration when cold
    Chaps, ive got a bit of an odd problem.
    First thing when the car is cold and you accelerate upto about 60-70mph there is alot of vibration, its got worse today. But then stops after about 5 mins of driving and not too sure what is causing it.
    I did wonder if it is wheel balance because it is a lumpy knocking.
    Any ideas appreciated.
    Might be worth checking the state of the CV boots, joints and driveshafts to see if they're in good fettle. Other thing is prop centre bearing...
      handn't thought of checking the center bearing, which could make sense if it was disturbed when I did the subframe bushes.
      • Fat Audi 80
        • 10547
        It is not misfiring is it??? Just a thought.
        The Perfectionist
        • MikeLarwood
          • Aug 2008
          • 278
          Does the wife use the motor in the evening and leave her bag under the seat?
          • goodall
            • Jul 2008
            • 810
            was thinking the same, damp plug leads (if 3b) or bad plugs just two possibilities
            • mcandmar
              • Apr 2004
              • 5118
              I had a similar problem that went away when i changed alloys, i assume it was a flat spot on one of them.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • Acidburn
                • 13459
                  Im pretty certain its not a mis fire because you get steering wheel judder when it occurs and engine sounds fine.
                  • GazzaG60
                    • 4133
                    do you have a loose wheel? heat expansion on wheel then holds it tight?
                      I checked all of the wheel bolts a week ago and they were all tightened up. But will double check it later
                      • Fat Audi 80
                        • 10547
                        That rules that out then!
                        I would check your tyres for debris. ( I have had a nail or screw in them before that that can be unpleasant at speed)
                        Wheel balancing
                        Flat spot on tyres
                        Loose wheel nuts! Scary
                        Cheers,
                        Steve.
                        The Perfectionist
                          Think I will have it up on the jack this afternoon and try to find out whats going on with this. Would be easier to pinpoint if it wasnt just within first 5 mins of driving,
                          • JP
                            • 1858
                            I had that problem when the seal went on my power steering pump and the fluid was running low. Fixed the seal and topped up the fluid and the problem was gone.
                            UrS6 Stroker + HTA3586 =
                              Cheers, another one on my list of bits to check. The small o ring on the PS pump has residue around it so its prob time to get that sorted too.
