Are koni's + H&R springs the best choice?
  • goinginzane
    • Aug 2004
    • 89
    Ive heard lots of good things about Koni's + H&R springs on a couple of forums.
    i still have a couple of questions.
    1. There are 2 types of sport koni's: the normal sport and the shorter sport version.
    If im correct the normal sport version is you dont lower your car more than 35mm and the shorter version is for if you do go lower than 35mm. Am i correct on this?
    2. Im planning/hoping to drive a lot on nurburgring and zandvoort (trackday etc.). I dont want adjustable shocks. Is a set of shorter sport koni's+ H&R springs good enough for the track or do you say not even close??
    The car im driving is a sedan 90Q but i dont think that makes alot of difference compared to an S2.
    Tanks
    Emiel
  • Prophet_dlx
    • Nov 2007
    • 262
    • Country: Luxembourg
    H&R is the best spring if you don't want coilovers, now if Koni or Bilstein is better... I don't know.
    RCN
      For track Bilstein is the best option, for everyday use Koni's
      • Sonic
        • Jul 2006
        • 5514
        I can testify that bilsteins are savage on the road, awesome on track
        S2Forum.com Administrator
        • Prophet_dlx
          • Nov 2007
          • 262
          but I can not compare it to koni sport as I never tried them.
          RCN
          • goinginzane
            • Aug 2004
            • 89
            bilstein are better for track!! does this mean that comfort is less than the koni's but the bilstein is harder and stiffer which is better in corners?
            I that case i will probably go for bilstein.
            How about which springs? I have a new set from eibach but some one just offered me a new set of H&R. Is H&R really that much better than eibach? or is eibach just fine only slightly less than H&R?
              H&R and Bilstein is the best track oriented combo. They flex less than any other shock and are stiffer.
              I've had all combo's on my old Coupe and my preference is Koni as i'm more street than track
              • Puglife
                • Jun 2006
                • 731
                Your so street jamo
                IS thecar used on the roads much for commuting? If not then it seems reasonable to go with a stiffer setup, but you shouldnt need to lower more than 35mm.
                Jay - pug_life85@hotmail.com
                1986 Audi UR quattro - WORK IN PROGRESS
                1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
                • goinginzane
                  • Aug 2004
                  • 89
                  I think the car will become lower than 35 mm out of it self. The car was orginal 2.3 10v. And is now an AAN setup with tubular exhaust manifold, intercooler, oliecooler, porsche brake , ...... So i think atleast the front of the care will be weighing more than normal. So when i buy the bilstein shocks for an audi 90Q 2.3 10v and use lowering springs for 35mm this lowering will be for a normal car. Mine weighing more will be i guess some what like 5 mm lower i think. I hope it wont be much lower.
                  H&R springs are the best on track oke but is eibach bad or is it worth to give it a try?
                  • 20Vcqdriver
                    • 829
                    Ditto that, I have tried numerous combinations in my 18 years of ownership and the H&R and adjustable Koni's have been by far the best for the road. Especially British roads!!
                    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
                    2004 A4 2.5TDi convertible, re-mapped to 180bhp
                    2011 A5 sportback 3TDi-Backbox delete, remap
                    • kritis17
                      • Aug 2007
                      • 53
                      • Country: Greece
                      I tried the H&R with the bilstein on my 90Q & it was too stiff for every day use & there was no traction on the slippery roads in Greece. I had to go back to the stock springs for more travel & to get the traction.
                      • TEKNOPUG
                        • 125
                        Bilstein now ships H&R springs with their Sprintline (name changed perhaps? Whichever is the more agressive of the two spring/shocks kits that they sell) kit so that should be enough to confirm that H&R are the way to go.
                        1990 Peugeot 205 1.9 Turbo 192bhp - 190lbs/ft
                        1996 Vauxhall Omega 3.0V6 Ex-Plod - cop motor, cop shocks, cop brakes, cop LSD. Cheap, tatty and comically sideways!
                          They used to be called the cup kit, Bilstein always shipped with H&R springs for the S2
                          • TEKNOPUG
                            • 125
                            Aha! They used to make Sportline and Sprintline kits - shipped with some rubbish spring that most people dumped and repalced with Eibachs (speaking from Hot Hatch experience). They now ship all kits with H&R springs.
                            • 20Vcqdriver
                              • 829
                              That would have been the very stiff Bilstein dampers. Knock the konis to minimum damping and the ride is easily considered comfortable for long journeys. Standard springs too soft and causes excessive pitching fore and aft during acceleraton/braking, far less sick making now...
