Subframes???
  • s2pete
    • Feb 2009
    • 46
    Subframes???
    Hi eveyone! Got a question that hopefully someone can answer!? Are the F/R subframes from a 2.8 quattro coupe the same as an S2?? 2.8 is a L reg and S2 is N reg?? Going to refurb subframes off 2.8 to go on s2!!! JOY!!
    N reg S2 coupe
    should work AFAIK, the rear ones are all the same, and the V6 subframe IIRC can be used with the 6 speed engine mounts
    • spink
      • 4382
      only difference between the V6 and 6 speed S2 fronts on the ones that i have seen is that there is an extra plate welded around the inside of the V6 subframe which will of course make it heavier.
      • s2pete
        • Feb 2009
        • 46
        Cheers guys! Thats made my day!!! I can get them stripped down and sent off to SPL for dipping and coating!!
        N reg S2 coupe
