Front tie rod bushes
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    this looks very interesting. are these bushes in need of any material to fit them in the rods to be more secured,or is it only a quick fit in?
      Looks great Rob - excellent work sir
      This I hope might be a solution to the coupe rear tie rod inner ends (albeit a differen size bearing) they are the same type of rubber bush with steel sleeve in them
      Watching with interest........
        Good thinking Mr 404 !
        • LHD_Kid
          • May 2006
          • 3696
          Looks like you have made 100's of sales alr=ready Rob....
          • goodall
            • Jul 2008
            • 810
            #20
            hum, that seems like a very good way doing it, where did you buy the bearing from and what was the specification, or do you not wish disclose that so can sell it
            • GT500
              • Jun 2006
              • 2181
              I am trying to find a supplier that can match the external and internal sizes.
              My prototype had to be machined to fit the external size. Having to that makes it more expensive, I should know more tomorrow...
              Rob..
              87 UR 20v ABY
              97 S6 Avant
                so you had to bore out the rod end to get an off the shelf bearing to fit mate?
                I wondered about another solution using the original steel sleeve and getting some nylon inserts machined to replace the rubber then pressing the steel sleeve back in...
                • goodall
                  • Jul 2008
                  • 810
                  #23
                  i considered doing that using some poly mini engine stabiles, they were wrong size, but also the tube from the original bush had a rough texture on the outside
                  as for bearing be best get bearing fit straight in, i have a bearing catalogue here, being the exciting person that i am so post the spec ill take a look, 1 for the book and 2 see if get a match
                  • GT500
                    • Jun 2006
                    • 2181
                    No, the external is the fit into the steering arm, the internal is the 10mm for the bolt. Machined the outer part of the joint, the inner was correct!
                    The steering arm is 23mm exactly. The new joint has to be 23.02 to get an interferance fit. That is the difficult part....
                    Think like this; the joint has to be able to rotate and articulate, thats why a rubber bush was used. Stiffening up the side to side movement is good like your nylon idea but no good for easy rotation (as the suspension moves up and down) don't want to stiffen that part as it cutts down the feel.
                    Rob..
                    87 UR 20v ABY
                    97 S6 Avant
                    • johne
                      • Apr 2007
                      • 1405
                      The steering arm is 23mm exactly. The new joint has to be 23.02 to get an interferance fit. That is the difficult part...........
                      Could you not use a bearing with an outside diameter of 23.00 and Loctite it in using Loctite bearing adhesive? I assume we'll be putting a large washers on top to ensure that even if the bearing comes loose, the tie rod can't slip off the rack!
                      John
                      • stiglet
                        • Aug 2007
                        • 1264
                        Originally posted by S2central.net
                        Rob - I think I like it... Look forward to more info - such as the 'how' and 'how much'
                        What do the suspension gurus think of this approach vs whats available from 034 ?
                        This place is great BTW !
                        This is definately a better option over the 034 version. 034 ones are on the limit of travel as Rob mentions. I had to use spacers on mine to get it to work properly but it amounts to the same thing. This is a no hassle approach. Wish you'd done this 4 months ago
                        If you could do the same for the rear then i'd certainly get a set from you.
                          Be a good seller this, interested
                          • GT500
                            • Jun 2006
                            • 2181
                            John
                            If you look how these fit you'll see even if it failed it cannot fall off as its sat between two parts and has a 10mm bolt through the middle!
                            I will be loctiting it in. but not relying on loctite holding the side to side forces everytime you move the steering wheel. Any movement results in a VERY annoying knocking!
                            Rob..
                            87 UR 20v ABY
                            97 S6 Avant
                              #29
                              John
                              I was just thinking the same actually - a big durty washer would be highly advisable for safety anyway wouldn't it ?
                                #30
                                Sorry yeah - its in a sandwich with the bracket... I see what you mean !
