Audi-Porsche RS2 front and rear antirollbar upgrade
  • Audi-Porsche Avant RS2
    • Sep 2008
    • 1041
    • Country: Italy
    Hello, I have open this 3D because I have search on the forum for a similar 3D but I have not find a clear one.
    I want know if on the RS2 is possible to make an upgrade on the front and rear antirollbar or not. I want mount the complete Powerflex set on front and rear.
    Thanks a lot!
    Bye
    Alessio
    My life and my loves
    Audi S6 C4 ABT Avant
    Audi S2 Coupe ABY
    Audi S2 Avant
    Audi Cabriolet 2.0E
  • lind4hl
    • Jul 2008
    • 2465
    neuspeed and whiteline does rear anti rollbars, the rear is sama as s4 b5 rear axle.
    i myself have an whiteline, and if you change rear, get the reinforcement brackets also! otherwise the subframe tends to crack
    you absolutely dont need to replace front arb
    Edit: here you have an pic on the reinforcement bracket from whiteline.
    (arb painted black, silver originally)
    the bracket is bolted under the subframe bushing on the pic and then at the arb bracket.
      • Sep 2008
      • 1041
      • Country: Italy
      Hello, if I change the rear antirollbar wich modify I must make? Thanks a lot!
      Bye
      Alessio
      Audi S2 Coupe ABY
      Audi S2 Avant
      Audi Cabriolet 2.0E
      • lind4hl
        • Jul 2008
        • 2465
        just buy an kit with the reinforcement brakets and bolt it up
        • M_GORDON
          • Oct 2008
          • 1295
          • Home: Isle of Man Current: Vatican City State
          The ABY rear ARB is of 12,5mm and the RS2`s 16mm
          But in front I don´t know
          photobucket SUCKS
            • Sep 2008
            • 1041
            • Country: Italy
            So if I buy the rear antirollbar of the Audi S4 B5 from Neuspeed I have already all the parts that I need? Also the powerflex or not? Thanks a lot! Bye
            Alessio
            Audi S2 Coupe ABY
            Audi S2 Avant
            Audi Cabriolet 2.0E
            • M_GORDON
              • Oct 2008
              • 1295
              Alessio
              What is the cheeper?
              photobucket SUCKS
              • lind4hl
                • Jul 2008
                • 2465
                audi_s2_aby: yes then you have everything you need
                • aRtiS
                  • Nov 2008
                  • 989
                  • Country: Latvia
                  The diameter of rear Antirolbar for s2 and rs2 is the same - 16 mm
                  In front - different, accordingly: 26(?) and 28 mm
                  Audi RS2 600 hp
                  Audi S2 1200 hp
                  MB 230E '83
                  https://www.facebook.com/ventracing.lv/
                  • M_GORDON
                    • Oct 2008
                    • 1295
                    But the ETOS not say the same
                    PS: if the S2 avant hace AA, the front springs are the same
                    photobucket SUCKS
                      • Sep 2008
                      • 1041
                      • Country: Italy
                      Hello, in the Neuspeed website I have find only the rear antirollbar for the S4 B5 that I think is the same for S2 Avant and RS2 Avant, for the S2 coupe I have not find rear antirollbar in the Neuspeed website but I have find it in the Whiteline website. My S2 Coupe ABY and also my RS2 have the Klimatronic, so which kind of front and rear antirollbar I must have if are originals? Thanks a lot! Bye
                      Audi S2 Coupe ABY
                      Audi S2 Avant
                      Audi Cabriolet 2.0E
                        • Sep 2008
                        • 1041
                        • Country: Italy
                        Hello, so on the front axle of the RS2 the only upgrade that is advised is the complete Powerflex upgrade? Thanks a lot! Bye
                        Alessio
                        Audi S2 Coupe ABY
                        Audi S2 Avant
                        Audi Cabriolet 2.0E
                        • lind4hl
                          • Jul 2008
                          • 2465
                          in the front suspension i would change this:
                          powerflex on anti-rollbar
                          powerflex in wishbones
                          topmounts from 034motorsport or something like this
