Knock Knock Knocking Arrgghh!!
  • neebover
    • May 2005
    • 359
    Help... looking to get my pride & joy back on the road soon and not far off now.. took her round the yard at work and even over the slightest bump or pothole is a not very good sounding knocking noise!! Any ideas guys??
    Chris
    Missing her lots!
  • Acidburn
    • 13459
    droplinks or top mounts?
    what sort of knocking and which part of the car is it coming from?
    • wilywyg
      • Sep 2008
      • 94
      Chris
      hi
      front, back or middle ?
      how bumpy is your yard?
      p
      LIFE WILL NEVER BE THE SAME
      • s2driveruk
        • 12696
        check your wishbone bush bolts for tightness as mine have worked slightly loose recently (stretched the bolt maybe...?) and that causes a knock too
        1992 3b S2 Coupe
        • neebover
          • May 2005
          • 359
          Hmmm... ok..
          Yard very bumpy
          Replaced bushes all round and tight as can be (Was knocking before replacing bushes)
          O/S/F Anti roll bar front link 8A0 407 465 replaced June 06
          Rear diff mounts replaced July 07
          Knocking appears to be coming from the front of the car so prob Anti Roll Bar???
          She has been SORN since July 2008
          If only I was as clued up as you lot!!! Thanks to the Forum!
          Missing her lots!
            ARB droplinks are my guess too
            • neebover
              • May 2005
              • 359
              Cheers.. I was going for them 1st..
              Chris
              Missing her lots!
              • Azman
                • 3205
                Would def hit droplinks first just done mine today.
                Dark Grey Avant
                RS2 FARB
                Alloy Subframe Bushes
                  Another vote for worn drop links
                  • neebover
                    • May 2005
                    • 359
                    Ok.. Pre Mot..
                    I need:
                    * N/S/F Anti Roll Bar Link (Knocking)
                    * Indicator Stalk
                    * 2 x Windscreen Wipers
                    Any thoughts on where to get these and prices?
                    Not bad considering been off road since July last year!! Are my emissions ok????
                    CO = 0.10%
                    HC = 27ppm
                    Lambda = 1.01
                    CO = 0.03%
                    Any advice welcome on parts above..
                    Chris.
                    Missing her lots!
                    • BrianSmith_S2
                      • Jun 2005
                      • 1342
                      • Home: Northern Ireland Current: British Antarctic Territory
                      Ok.. Pre Mot..
                      I need:
                      * Indicator Stalk
                      CO = 0.10%
                      HC = 27ppm
                      Lambda = 1.01
                      CO = 0.03%
                      Chris.
                      Drop links from german and swedish are ok and are metal. I would replace the pair, think i paid abour £24 each last year. Get the wiper blades from there as well... they do bosch ones quite cheap. Not sure about the indicator stalk tho.
                      Emissions are ok
                      for comparison mines were (for an ABY K reg)
                      CO = 0.02% (limit 0.20 %)
                      HC = 9ppm (limit 200ppm)
                      Lambda = 1.004 (limit 0.970-1.03)
                      CO = 0.00% (limit 0.30%)
                      Limits for the 3B are higher and doable without the cats
                      • neebover
                        • May 2005
                        • 359
                        Cheers.. I'll get onto them.. appreciate that
                        Missing her lots!
                        • s2driveruk
                          • 12696
                          Emissions are ok
                          Brian was you catted or not for those figs I can't remember....
                          1992 3b S2 Coupe
