Power steering issue
  • rj scotty
    • May 2006
    • 2195
    Hello all, not been on for a while busy with jobs on house and things
    Right, Been out for a spirited drive this evening (got to love the s2 sometimes)
    when locking the wheel very quickly, say in a chicane the steering fights you as in resistance is felt for a second then all is well.
    Fluid level is good and system was flushed not so long ago.
    Is this likely to be the easy to change pump or the pain in the backside steering rack ?
    All help appreciated
    cheers
    rich
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
  • mcandmar
    • Apr 2004
    • 5118
    Most likely a slipping belt. The limit of the pas system is very easy to reach, try and drive quickly through a slalom and you will see what i mean
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • rj scotty
      • May 2006
      • 2195
      So this looks like a trait of the car rather than a fault, ill check the belt though
      As you say its only when changing steering direction very quickly that this happens.
      cheers
      rich
      • Barber
        Banned
        • Apr 2009
        • 208
        the same happens with my S2 and my old coupe gt!
          IIRC there is a restrictor in the fluid line to the rack? Has anyone tried running without that? Just wondered if it might reduce the PAS pressure and give less assistance and maintain more stable pressure at the rack
          • gedu
            • Feb 2007
            • 295
            Yes, restrictor has been dumped lots of times, only thing seen after wards has been a bit more noise from powersteering.
            All quattro products have been dermatologically tested, and are safe for daily use.
