Hi guys,
Now before I lose my rag completely with the car, I have been getting the legs off today so that I can get new insets put in as one is leaking, (upgrading to RS2 Items too) so one side bit of a struggle with the good old Roll bar link (metal one) but all good in the end after having to use a nut splitter to get the steering arm ball joint nut off but at least it came through the arm with a few hammer bangs. Soooo onto the passenger side, this time no probs at all with the roll bar btu spent 3 hours on the ball joint on the steering arm with still no avail, need to get it shifted asap so I can get the legs in tomorrow and the car back on the road by PM tomorrow too. Erm suggestions,
Used large ball joint splitters (couldn't quite get em in the gap to be of any use though)
USed leverage and the good old hammer (slightly bent the steerning arm
but managed to get it back into shape).
That is lever up and down too....
Stuck did have it soaking in 3in1 all night too to help today but obviously not.
So going to need a new one but also can we buy the adjusters seperatlt too???
Az
but managed to get it back into shape).That is lever up and down too....
Az
to cut a slot in the top of the threaded shaft just above the nut you can hold it with a large flat headed screwdriver to stop it spinning while undoing the nut. It worked for me and I now always slot them before replacing them.
