Poly Bushes - Avant
  • madpugger
    • Sep 2007
    • 1901
    Poly Bushes - Avant
    Does anyone know, do powerflex do the rear lower wishbone outer bush?
    I called them and they 'said' they do them, but I don't see them listed so I wandered if anyone has fitted them?
    Mike
    Le Mans 2012
    Nurburgring 700
    1995 S2 Avant
  • Big Lee M
    • 2571
    I've got a full bush set to fit front and rear I'll get the part number when I get home tonight.
    Just some finishing touches to do now
    • Flat on my back
      • Jan 2007
      • 2449
      You mean the large bush in the 's' shaped cast arm, then no.
      Carlos.
      • madpugger
        • Sep 2007
        • 1901
        Yeah, where a ball joint would be on the front.
        Le Mans 2012
        Nurburgring 700
        1995 S2 Avant
        • Flat on my back
          • Jan 2007
          • 2449
          Well...
          there's a thing...search for threads by Skull (you'll need 2 dots over the 'u').
          He's trying to get some PU ones made...
          Or you talking about the smaller arm that comes off the cast arm? (sets the rear toe).
          Balljoint...that's got me confuzed...we need a piccy.
          Carlos.
          • madpugger
            • Sep 2007
            • 1901
            Ok, on the rear there is a lower wishbone, an upper wishbone and the hub carrier.
            Lower wishbone has:
            Front inner bush
            Rear inner bush
            Shock absorber mounting
            Hub carrier mounting on the outer (This is the bush not listed as far as i can see - the bush is actually in the bottom of the hub carrier)
            Upper wishbone:
            Inner front and rear bushes (the same as each other)
            Outer bush where the hub carrier is bolted to it (above the wheel)
            Hub carrier:
            This has one bush at the bottom, where it connects to the lower wishbone. (again, this is the bush I am after) It is the one that has the camber adjust bolt through it.
            It also has the mounting for the ARB Drop Link.
            Le Mans 2012
            Nurburgring 700
            1995 S2 Avant
            • istoo
              • Mar 2006
              • 408
              totally OT
              saw you parked up at the beach a few weeks ago... waved but thought it was rather pointless given you would have no idea who i was!
              Spied a huge increase in S2's lately around the shire.
              • madpugger
                • Sep 2007
                • 1901
                You did? Oh i must have been stopped to eat a BK!
                I haven't seen an S2 for aaaages!
                Le Mans 2012
                Nurburgring 700
                1995 S2 Avant
                • M_GORDON
                  • Oct 2008
                  • 1295
                  • Home: Isle of Man Current: Vatican City State
                  HI!
                  I have too a avant and I must change all pieces (I don´t change they).
                  I see 034 motorsport sell some of Powerflex to our cars, but they do sell all in one packet?
                  THX
                  photobucket SUCKS
                  • Big Lee M
                    • 2571
                    Sorry totally forgot about this,the part number for the rear lower arm bush from Powerflex is PFR3-206
                    Hope this helps
                    • S-Express
                      • Nov 2006
                      • 1133
                      Hope this helps
                      Thats the rear lower arm rear bush, not the rear lower arm outer bush.
                      I've just totally rebushed my car and could not get poly's fpr the rear lower arm outer bsh, so had to use OE instead.
                      • lind4hl
                        • Jul 2008
                        • 2465
                        i am going to make my own bush in the hub. maybe i will do some more..
                        • Big Lee M
                          • 2571
                          Have anyone got a pic of the bush that we are on about here???
                          • lind4hl
                            • Jul 2008
                            • 2465
                            stolen from the s2forum gallery:
                            • Ducky
                              • May 2006
                              • 636
                              I've just rebushed my car today and I was wondering about this lower bush too...guess I'll have to go OE for now. Does anyone know if there is a poly bush available for the rear tie rod (8A0501530C) that has a ball joint at one end?
