thanks for your help. Ok i think i will get OEM rear diff mount and get the 034 street density tranny mounts and engine mounts. Ill polybush the wishbones and and arbs bushes. Does that sound a decent set up?
Do i need all this lot?
anyone got the part number for the rear diff mount and ill order it tomorrow. Also street or track density? Really cant decide on what to doLast edited by stevieyid; 31 May 2009, 22:24.3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
(just need the RS2 Airbox)Comment
yeah i think i have decided on the street density. Just to double check these are the right ones arent they:
im ordering two of these: http://www.034motorsport.com/product...roducts_id=983
And two of these:
Also are these OEM diff mounts for a 93 ABY Coupe? I bought them ages ago but i cant remember what they are:
no you need 2 engine mounts and 2 transmission mounts in addition to the two you have above, and yes they are correct, you only need one of the rear diff mounts, although that one you linked was for the b4/5.
Ant91' Coupe quattro 20v - project
KW V2s and other goodies
now gone
03' BMW 330CI - Sold
08' A5 Coupe 3.0l tdi quattro - Sold
57' BMW 525d M Sport TouringComment
also just read you have an aby, in which case those engine mounts will not fit as the ABY is different to the other I5s, you need these ones - RS2 engine mounts
if you read the buff then it mentions the ABY too.
now gone
sorry linked to the wrong products. I currently have 2 of these in my basket: http://www.034motorsport.com/product...roducts_id=983
And two of these:
http://www.034motorsport.com/product_info.php?products_id=984{6}230
Is that right? im going to get OEM mounts for the diff from quattrocorner unless the ones i have above are for the diff.3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
those transmission mounts are spot on and yes 2 is correct, assuming you have 2 already. you need 4 in total for your car, two in the gearbox and two on the rear diff. look up at my previous post for your engine mounts, the ones in your basket are for 3B/7A.
now gone
