nothing to do with the subframe. yes the brackets are a good idea
It's everything to do with the subframe, the brackets were created as larger anti-roll bars caused cracking in the subframe around the mounting points in the stock position.
The bars distribute the load better across the subframe rather than on the stock mounting points.
this is what i remember from previous links/postings....
Can I assume there is still a potential issue if you run a larger RARB without the brackets?....
