violent knock, vibration
  • nikmay
    • Aug 2007
    • 112
    • Home: United Kingdom Current: Germany
    Hi all, I am getting a real violent vibration come knock from the front end when I take my foot off the go pedal at about 80mph, it stops as soon as i put my foot on the brakes, thought at first I was losing a bleeding wheel, but thankfully I wasn't, just recently fitted new top mounts which were knackered, but symptoms still remain any ideas?
    All Hail the mighty Quattro
  • nikmay
    • Aug 2007
    • 112
    Nobody got any ideas??
    • Knight Rider S4
      • 3541
      I would check:
      Link arms off the ARB
      ARB bushes
      Make sure calipers are tight and not loose
      Swing arm bushes for play
      Hopefully it is one of the above
      Steve
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
      • Acidburn
        • 13459
        have you checked as many of the nuts/bolts as possible at the front end i.e.
        wishbone
        upright
        suspension to steering arm bolts
        the 2x bolts that hold both steering arms to the steering rack
        wishbones
        I had something like this except mine was around 100 ish and I found the wishbone nuts/bolts had worked slightly loose.
        • s2_bo
          • Oct 2005
          • 6067
          Also worth checking the subframe bolts as i had a similar problem after i had a 'garage' refit my subframe and they only did the bolts up hand tight.
          91 S2 coupé - RIP
          98 S8 - Luxury barge
