"Clunk" after H&R springs fitted
  • DarrenM
    • Aug 2007
    • 1227
    Just got the lowering springs on but there is a clunk front passenger side on left hand lock, gonna change the top mounts tommorrow to be sure but any ideas?
    Its sounds almost as if its not sitting in the round cup housing properly just on the one side.
    Or the spring maybe on upside down.....
    • s2driveruk
      • 12696
      check its located in the perch and also the cap whichsits between the top of the spring and the top mount. Mine used to twang when on lock when the top cup had moved a bit
      1992 3b S2 Coupe
        Also check your drop links, I've had it in the past drop link has failed right after changing top mounts
        • DarrenM
          • Aug 2007
          • 1227
          Thanks chaps, spring def the right way up,will check the other bits tho.
          cheers
