Alignment spec!
  • stevieyid
    • Apr 2005
    • 2251
    Alignment spec!
    Just been reading on s2central.net on the alignment spec. Is it the same if the car is lowered? My car has konis with h&r springs on sojust wanted some thoughts on the spec.
  • s2driveruk
    • 12696
    negative camber and pretty neutral toe works well for me on H&R and Bilsteins. car feels well planted but the steering and turn in is sharp. Only downside is that the tracking goes off fairly quickly i have found (Maybe its that combo and sh*t roads) and you then get the car feeling loose and very floaty
    1992 3b S2 Coupe
    • epic
      • 1317
      I have the same Koni / H/R set up on the car and have always used the standard settings.
      This is what was suggested by Kim Collins when he fitted them more than 10 years ago
      • stevieyid
        • Apr 2005
        • 2251
        How about these setting fronts to about 1. 1/4 to 1.1/2 degrees negative and about 1/4-1/2 degree toe out. The rear set minimum negative 1/4 to 1/2 degree and toe parallel or 1/4 toe in
