How to change the "bomb" ?
  • Lighthouse
    • Jul 2007
    • 229
    • Country: Norway
    I searched and looked a bit on the forum, but I couldn't find a "how to" thread on how you change the "bomb". Does anyone have a good guide?
    '10 A5 Coupè 2.0TFSI REVO
    90 quattro
    X- 91 S2 Coupè 467hp, 670nm!
    IIRC:
    First depressurise the system by pumping the brake pedal till it goes hard
    Jack up passenger side front
    Locate bomb under battery tray area
    undo hydraulic fixings & pinch bolt on the bomb mounting bush
    catch G002000 fluid in a oil pan or something - don't get it in your mouth its rank
    remove bomb
    replace with new bomb & copper washers on banjos etc
    tighten up hydraulic fixings & mouting bush bolt
    refill PAS fluid
    start engine and turn steering wheel side to side a few times to bleed system
    top up fluid as neccessary & check for leaks
    Drop car down & enjoy not having spongey brakes or the autocheck do your head in every 5 minutes
    • Fat Audi 80
      • 10547
      You make it sound so easy alex!
      Is it?
      The Perfectionist
      • merlin's S4
        • Jan 2005
        • 1539
        IMO - Yes! Especially after what you've just been through Steve, this is a walk in the park!!
        • s2_bo
          • Oct 2005
          • 6067
          Its harder if there is a battery in the way, relocating the banjo bolts and getting them to bite is a complete PITA though, i have changed 3 of these and every time its taken almost twice as long to get that dam bolt to bite then to remove and refit the bomb its self. Apart from on the LHD RS2, that was a piece of cake
          Instructions above are spot on, but renew fluid with G004000 from the dealers, its about £7/l, you need about 1.5l - 2l if your draining it all etc.
          91 S2 coupé - RIP
          98 S8 - Luxury barge
            Only thing I would add to that is to renew the little rubber mount doobries on the bomb bracket - they can crust up really badly over time - they are cheap as chips and make for a clean rebuild that you know has fresh rubber.
              Piece of p*ss with the engine out isn't it Alex
                Bit of a long way to do it but does make life easier
                • mcandmar
                  • Apr 2004
                  • 5118
                  -Clamp the rubber hose from the reservoir, makes less of a mess...
                  91CQ20v - Gone to a new home
                  93UR-S4 - The Magic Carpet
                  94S2Bus - The Emerald Express
                  • Lighthouse
                    • Jul 2007
                    • 229
                    • Country: Norway
                    Thanx for a good writeup
                    90 quattro
                    • Bram
                      • Aug 2006
                      • 2582
                      Thanks for the write up. I will do my bomb in the next few weeks
