violent vibration coming from front at speed
  • craigs4
    • Jun 2009
    • 129
    hi, i was wondering if any body could help me , i have a 92 s4, and this morning there was a loud violent vibration coming from the front end when i steered to the right slightly at hi speed any ideas?
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    Engine shield under the car?
    • chezz
      • Apr 2007
      • 440
      Wishbone bushes worn? I had a similar problem and serious vibration would kick in at 60 -70 mph.
      You need to get under the car and check anything and everything suspension related, make sure you have no serious problems developing.
      • driftin jo
        • Sep 2007
        • 2222
        I had that last year and it was the ball joint on the end of the wishbone, when i took it off you could slap it up and down there was that much play in it.
        • s2driveruk
          • 12696
          yup, plenty of things could be causing it, et the front end up on axle stands and have a decent poke about, is it coming up through the steering wheel or is it a body shake or just noise?
          1992 3b S2 Coupe
          • craigs4
            • Jun 2009
            • 129
            hi cheers for the replys, is coming through the steering wheel and vibrating ?
